help on a jacobsen homelits 824 snowblower
Old 12-15-07, 10:34 PM
I can't find any info on what the problem may be with the auger and blower not turning. Any suggestions would be appreciated.
The Blower turns very very slow, and the auger does not want to turn at all, even when pryed. They both turned freely this past May when I purchased it. Hope to find some suggestions before spending $$$ at a shop.
Bob
Old 12-16-07, 07:23 AM
I would look into the belts and pulleys that run the auger and rotor. I'd assume its belt driven and may have a worn/snapped belt or the belt may be off the pulley.
Old 12-16-07, 08:22 AM
indypower500's Avatar
First thing I would do is take off all the belts(make sure you keep the seperated so you know which is which). Then see if the impeller & auger will turn. And listen as you turn. A growling noise means you need bearings replaced or the impeller is bent. If nothing turns freely, then you may need to rebuild the auger gear box, new bearing/bushings. You may also have rusted shafts.
