12-19-07, 06:04 AM
Who made Sno Trac snowblowers need Manual
I have Sno Trac snowblower model 315 961 502 serial No.885793. It's a 33 inch 2 stage with Tecumseh cast iron bore engine. No info on engine but suspect it's at least a 10hp. From what I have been told it is about a 1985 model and work real well as proven by last 2 storms that came thru here both over 20 inches.
Other than that I have precious little information other than some part numbers when it was last serviced.
3LK360 belt
754-0194 belt (MTD part)
713-0194 sprocket
Any manual will do and I am thinking this brand was made by one of the popular manufacturer as a private label.
Thanks for any information or insight provided
3LK360 belt
713-0194 sprocket
NH
12-19-07, 08:21 AM
The numbers looked like MTD to me. The model number and part number you used. So I looked here :
http://www.jackssmallengines.net/parts.asp
Click on the box "parts look up", then MTD on the drop down list, then YardMachine (last one on the list) scroll down to snothowers, 1985 models, scroll down to 315-960.
If this looks like yours, it is a 1985 by MTD.
Posted By: Pumpdoctor I have Sno Trac snowblower model 315 961 502 serial No.885793. It's a 33 inch 2 stage with Tecumseh cast iron bore engine. No info on engine but suspect it's at least a 10hp. From what I have been told it is about a 1985 model and work real well as proven by last 2 storms that came thru here both over 20 inches.
3LK360 belt
713-0194 sprocket
12-20-07, 04:22 AM
Sno Trac snoblower
THANK YOU. Bang on the money!!!!!
Posted By: indypower500 The numbers looked like MTD to me. The model number and part number you used. So I looked here :
