Which Spark Plug # to use on a 10HP Tecumseh HH100?
Old 12-21-07, 07:21 AM
I have a 1974 10HP Tecumseh HH100-115181E Serial-4255E, Solid State Ignition, on a tube frame Bolens Yard Tractor. I am having a of a time trying to get it running for any length of time. My question on this thread is what is the correct plug to use. The one I pulled out is a RJ8 but I read on a Bolens Forum that the correct plug is an RJ8C.
What is the difference between the two and should I only be using the RJ8C.
The RJ8 was in the engine when I bought it (used) last year.
I'll start with the correct plug and take it from there.
I have other problems with the tractor as well. Should I start a new thread for each individual problem or just keep all the problems on this thread?
Thanks,
Rob
Old 12-21-07, 09:27 AM
Found out by myself
Just got done looking at the Tecumseh website and found where it gives the correct plug which is a RJ8C. It's off to the parts store with me.
Rob
Old 12-21-07, 10:04 AM
Gunguy45's Avatar
Super Moderator
Thread question
Glad you found what you needed.
If you can edit your original post's title, I would keep it in this thread. If you can't edit the title, start a new one with the other problems you are having.
Best in 2008
Old 12-22-07, 08:05 PM
Thanks,
Rob
From the Champion spark plug website:
http://www.championsparkplugs.com/re...ID=5483&mfid=2
RJ8C or J8C for the HH100. It didnt list an RJ8, perhaps that's an obsolete number. I bet if you emailed Champion they could tell you about that RJ8 plug.
Good luck,
Paul
Old 12-23-07, 06:59 AM
indypower500's Avatar
All Champion numbers have been superseded to a "C" suffix.
J8 is now J8C. The "C" was added when they went to copper core plugs. C stands for copper core.
Old 12-23-07, 09:27 AM
CAMINO KID's Avatar
The RJ8C is the orginal style plug for this engine and has a 3/4 in hex. We have found that as the engine ages you might find that the J19LM will give you better plug life and not foul out. The J19LM or RJ19LM have a 13/16 in hex and are hotter plugs for air cooled engines.
