Snowblower moving very slowly
Old 12-22-07, 07:09 PM
1
I have about a 7 year old Craftsman 7.75 HP snow blower. This year it started moving very sloowly and with little power. I sometimes have to push the thing when before it would litterlayy pull me along the slipery driveway. Any suggestions?
Old 12-23-07, 12:20 PM
R
Not sure how yours is adjusted, but when you engage the drive, you are pulling a pulley down and putting tension on the drive belt. If you belt is 7 years old, you may need a new belt, or adjust the cable going to the pulley. The belts are not all that hard to replace usually, and cost no more than $15.
Old 12-23-07, 01:00 PM
_
Does the hand control to engage the drive go down to a lever on the back of the snowblower and attach with a spring?
If so disconnect the spring from the lever, then slide the spring up the rod, exposing an adjustment nut underneath.
Run the nut up the rod a few more turns to put more tension on the spring and the snow blower should take right off. I just repaired one like this yesterday, but it wasn't a craftsmen so I'm not sure if your setup is like this or not.
Good Luck!
Old 12-25-07, 04:43 AM
1
____Brandon and refury, Thanks both for your reply. I will take a look and post a reply when I find out what works as a fix. Hoping simple nut turns wil do the trick!
Old 12-25-07, 09:56 PM
hopkinsr2's Avatar
If the adjustments don't work for you, take a good look @ the friction wheel. They can wear & still look good if you don't know how thick the origional one was!!
