Craftsman 536.819501 snow blower
Old 01-01-08, 05:37 AM
Craftsman 536.819501 snow blower. Belt broke; bought a replacement belt, but don't know how to install. There are two pulleys which appear to have ridges that match the ribbed belt. Other pulley (tensioner?). How does the belt go on? Ribs down and over the top of the tensioner? Ribs up and under the tensioner? Help, snow is coming and I need to get this thing running.
Thanks in advance.
Old 01-01-08, 07:38 AM
indypower500's Avatar
Belt goes on with the ribs in the ribs on the pulleys. Tensioner pulley goes on top of the flat side of the belt. You can see a diagram here: http://www3.sears.com
Just type in your 536.819501 then click "view diagram" to see the set up.
Thanks in advance.
Old 01-01-08, 07:57 AM
Also look on the inside of the cover when you remove it, often there is a belt routing diagram on there.
Old 01-01-08, 08:06 AM
Thanks; I figured that was the correct way, but the first time I started it up, it threw the belt. The belt seems really loose, but I'm sure that it's the correct belt. It actually seems a tad smaller than the one that broke. Any way to adjust anything to make it tighter?
Old 01-01-08, 05:49 PM
hopkinsr2's Avatar
You may be able to adjust the idler pulleys, but if it has the belt fingers they have an adjustment as well. The fingers keep belts from flying off on disengagement & the idlers keep tension on them during operation, depending on the type of drive.
Old 01-02-08, 12:10 PM
puey61's Avatar
You have a Murray manufactured snow thrower and you should have gotten belt part number 319596MA as a replacement. Did you? You have an older machine and I don't recall if you have an adjustable control cable or not so have a close look if there is a threaded adjuster integral to the cable or, if not, then perhaps optional holes to install the Z-ends of the cable in order to reduce slack.
Old 01-03-08, 12:34 PM
That is, in fact, the belt that I got. I have no idea what the rest of your message means. What cable? What holes? What is a Z-end. Sorry, I am about as far from a gearhead as one can be, but I'm always willing to try....
