Snowblower...throws fine...won't drive
eaa1964's Avatar
MI
01-02-08, 03:13 PM   #1
This is my 3rd season with a sears craftsman 9.0HP 28inch cat track snowblower.
Today I went to clear up what was left behind from yesterday's 14inches. started up fine, engaged in fwd and rev, threw snow. completed the job then could not auto drive it back to barn. If i got snow accumulated, i was able to throw it. bottom line...I had to push, pull and grunt my way back 250 feet.
this is my first snowblower so i don't have a lot of knowledge. i am assuming there is some sort of drive belt or two but don't have a repair manual. any thoughts or suggestions? also instructions on how to?
thanks from snowy michigan
EAA
indypower500's Avatar
NH
01-02-08, 05:10 PM   #2
Can you please post the model number?
eaa1964's Avatar
MI
01-03-08, 04:21 AM   #3
model number 31AE7H8G799 or sears number 07188890000
two stage 4 cycle
eaa
NH
01-03-08, 08:18 AM   #4
The first thing I would check is the drive belts. You have a total of 3 belts on that snowblower. 1 drives the auger, the other 2 drive the tracks. Check to see if they are worn or if 1 is broken. Belts are located under the plastic cover between the engine & auger housing.
Do you have a heated or semi-heated garage? The cables for the "power steering" have been known to freeze while using causing the tracks to lock up. A Hair dryer will thaw them out if you don't have a heated garage.
you can find a diagram here:
http://www.buymtdonline.com/webapp/w...10101_19502_-1
click on "launch illustrated look up tool", then type in your model number.
eaa1964's Avatar
MI
01-03-08, 03:01 PM   #5
thanks for the tips. I will look tomorrow afternoon when I get home from work. I have put the unit in the garage up at the house...the barn is -4 degrees farh. the house garage is built into our basement. never really gets below 40 degrees.
I will let you know how it works out. again, thanks.
Elizabeth
