MI
OK
01-05-08, 02:43 PM
Enter the spec value 155636v
at this location to download parts list pdf.
http://www.landscapepower.com/tecumseh_partslists.html
look for ref item 72 in middle of 1st page.
plug is on bottom of crankcase, oftentimes another is on backside of case as well.
hope this helps,
thanks,
hope this helps,
thanks,
MO
01-06-08, 07:14 PM
flirty1;
It was advice not sarcasm, you have the item needing service, we have only your description of the item, the sooner we can get to the source, the sooner the problem gets solved. Now, did you remove the bolt, did oil flow and is the problem solved. Have a good one. Geo
