Replace Ariens Auger Belt for snowthrower?
Old 01-05-08, 02:15 PM
Question Replace Ariens Auger Belt for snowthrower?
I have an old Ariens Snowthrower. appx. 15 yrs. The auger belt broke and I can't see how to replace it. HELP it's snowing.
Thanks in advance
Bob
Old 01-05-08, 03:49 PM
What is the model #? It should be on rear of tractor left hand side.
Did you remove belt cover? If so 1 or 2 belts?
Old 01-05-08, 04:26 PM
Ariens
It has 1 belt
looking down at the shaft it looks as if it goes through the engine, pully wheel and into the auger? I think it's a 10ML 60D
Old 01-05-08, 06:56 PM
hopkinsr2's Avatar
If you remove the 2 bolts @ the top of the collector where it meets the power unit & disconnect the chute control, the machine will "Fold" open. Thru the opening of the belt cover you removed, You can feed the belt around the pulleys. Pull the auger engage handle slightly when you fold the unit together & you'll be blowing snow in no time!!! Roger
Old 01-06-08, 09:04 AM
Thumbs up Roger, You are the Man !
I had no idea what you were saying and I thought I had low reading comperhension. But I went out, looked at what you suggested and bam the light came on. All is well new belt instaled and ready to blow some snow Thanks, Roger!
Old 01-06-08, 09:44 AM
hopkinsr2's Avatar
Glad you're going again. Thanks,Roger
Old 01-07-08, 02:24 AM
puey61's Avatar
By the way, your machine is 40 years old, not 15. But that's a good thing, that's when an Ariens was made to last.
Old 01-26-11, 03:49 PM
I have an arien 8524 and my propeller is not working. I think the auger belt needs to be replaced Can anyone help me please????? First where can I get the belt ? And last how do I replace it???? Please help me anyone....
Old 01-26-11, 10:03 PM
hopkinsr2's Avatar
You can probably get the belt @ any OPE shop... The above instructions should get you dialed in,,,Split it in 2 @ the center & be aware of the brake... Roger
