Broken pull start handle
sprinter10's Avatar
ME
01-09-08, 10:29 AM   #1
I have a 2001 Craftsman 9 HP Tecumseh snowblower. The plastic handle broke off the pull start while trying to start it and the rope, of course, went back through the hole. What do I need to do to replace the handle? Can I just tie a new handle onto the old rope? I'm hoping this will be an easy fix. Thanks for your help.
flirty1's Avatar
MI
01-09-08, 10:30 AM   #2
if theres enough rope just thread it through the handle and re-tie it but you will need to re-tighten the spring before putting the handle on.
sprinter10's Avatar
ME
01-09-08, 10:50 AM   #3
Re-tighten Spring?
Flirty1, thank you for your response, but how do I re-tighten the spring? This seems to be the key to the whole deal. Thanks again.
michaeljp86's Avatar
MI
01-09-08, 01:21 PM   #4
Ive done this a million times, Youll have to take the cover off and get to the back side of the spool. I wind the spool up as tight as I can until it stops then let it loose about 3 turns and slide the cord through the hole and put the handle on. When the spring pops off the spool is when the fun starts.
If I was you I would replace the cord, at ace hardware they are like 3 bucks with a new handle.
