MTD Snowflite 5/20 help needed
Old 01-20-08, 07:24 PM
dcjredline's Avatar
Hi again, I just picked this machine up today and I am looking for the info on it.
Machine #s 310-430-1 G112B
Engine # - HS50 67174C Serial # 9138B
Looks like it needs new belts, carb work, wiring repair, and a new spring for the drive clutch return. Along with a new pull start recoil assembly. Any one either have some good info on these or a place where I can get the info I am seeking?
Old 01-20-08, 09:11 PM
repair_guy's Avatar
New Member
Old 01-21-08, 06:08 AM
You're probably more interested in the machine, but the engine info... enter 67174C at:
http://www.landscapepower.com/tecumseh_partslists.html
then enter carb 632107 at:
http://www3.sears.com/
for breakkdown and repair kit part #
hope this helps,
thanks,
Old 01-21-08, 07:39 AM
dcjredline's Avatar
All 3 sites are a big help THANK YOU BOTH very much. I hope to get working on this in the coming weekend.
Old 02-04-08, 10:58 AM
dcjredline's Avatar
Well I still cant find any parts that are what I need. The model # is 310-430-105 G129B. It IS called the throttle control switch but I cant find one. I am going to the local shop today for carb parts (LOST THE NEEDLE) and I will ask them but anyone else have any ideas? Can I rig this to work?
Looks like the main thig it does is shut the snowblower off really. There doesnt seem to be a way the resistance would vary from movement but maybe.
Old 02-08-08, 12:02 PM
dcjredline's Avatar
Found it. I guess I should just go there from now on, nothing going on here. What happened to everyone?
Old 01-28-09, 10:54 PM
mtd has a website to get a manual
PDF Manual Web Archive
you'll be asked to enter your model number (like 310-430) and then your serial number (like G092B). The manual has parts diagrams and parts lists in it. Then you can take your part numbers to one of the sites for replacement parts:
MTD Products Landing Page
or
MTD Snowblower Parts and Snow Thrower Parts
Good luck!
