spray paint hardening?
laflaone's Avatar
FL
01-30-08, 07:53 AM   #1
I am going to spray paint an electric motor, after sanding to get the rust off. Spray paint is handy, but it never seems to dry hard enough to be scratch resistant. Any suggestions on hardening spray paint?
bontai Joe's Avatar
PA
01-30-08, 08:10 AM   #2
I use a 100 watt incadescent light bulb in a reflective shade to kinda bake the paint dry. I use the cheap clamp on work lights with the aluminum shades.
Gunguy45's Avatar
Super Moderator
AZ
01-30-08, 08:16 AM   #3
paint
the spray appliance epoxy dries hard, but not sure if you could get it in a color you need. It does take a loooonnng time to dry/cure as well.
Vic
"I sometimes wonder how some people ever made it to adulthood..."
marksr's Avatar
TN
01-30-08, 11:20 AM   #4
Ya, letting it cure is the main thing. It takes the paint a lot longer to cure than it does to dry.
The only other alternative would be to paint with an industrial enamel or an automotive type paint - probably over kill
retired painter/contractor avid DIYer
joemow's Avatar
MI
01-30-08, 03:04 PM   #5
Posted By: laflaone I am going to spray paint an electric motor, after sanding to get the rust off. Spray paint is handy, but it never seems to dry hard enough to be scratch resistant. Any suggestions on hardening spray paint?
Put like 3 or 4 coats on it thin a 1 or 2 coats of clear coat hope this helps Joe
laflaone's Avatar
FL
01-31-08, 04:55 AM   #6
Thanks to you 4 for your replys. Some good ideas.
