snowblower gasline strainer
jimfh's Avatar
PA
01-30-08, 12:08 PM   #1
I have a 5hp Briggs &Stratten,& found rust inside the gastank,so I cleaned it out, then I found a little 1/4inch strainer in the tank which sits above the gasline in the tank,the problem is that it is distorted, my question is ,do I have to put this strainer back in or wil it run without it , how do I get a replacement ?Thank you!
repair_guy's Avatar
New Member
AL
01-30-08, 02:25 PM   #2
It doesn't have any thing to do with the running,less your using dirty gas.But I recomend that you replace it.
Go to your local B&S dealer tell them the model and type # of your engine,and what you want.The'll be able to pull one out of stock for you....or order you one.
joemow's Avatar
MI
01-30-08, 06:01 PM   #3
Posted By: jimfh I have a 5hp Briggs &Stratten,& found rust inside the gastank,so I cleaned it out, then I found a little 1/4inch strainer in the tank which sits above the gasline in the tank,the problem is that it is distorted, my question is ,do I have to put this strainer back in or wil it run without it , how do I get a replacement ?Thank you!
nothing to do with running just filters gas like repair guy sead
