engine wont run above a idle
Old 02-05-08, 07:21 PM
i have a kohler 12 horse and it will not run above a idle but it starts and run good at a idle and i have shaved the heads 40 thousands can someone give me some help to make it run and full throdle thanks
Old 02-05-08, 07:25 PM
[i have a kohler 12 horse and it will not run above a idle but it starts and run good at a idle and i have shaved the heads 40 thousands can someone give me some help to make it run and full throdle we are building a new tractor and wont to get started so we can pull it
Old 02-06-08, 12:35 AM
cheese's Avatar
Sounds like a carburetor problem, but there could be other problems. What engine do you have?
Old 02-06-08, 01:25 PM
Sounds like you are not getting adequate fuel.
Check the fuel line for cracks which may be draining off the gas when you try to accelerate the engine.
Good luck!
Old 02-06-08, 01:28 PM
what happens when you give it gas with the throttle. does it die or stall or just stay at the same speed. if it stays the same speed maybe its not the engine but a cable that came loose or broke.
Trackbacks are On
Pingbacks are On
Refbacks are On
