B & S 11HP Synchro Balance
Old 02-08-08, 07:49 PM
H
Hi, new here, have a really dumb question.. I took apart my snow blower engine to find source of Knock ,
How do you "time " the synchro balance shafts to the crank shaft?
this is model; 252416
thanks in advance
Old 02-09-08, 03:36 AM
H
so pardon the confusion,, if you 'time' the cam and the crank gears, then instal the PTO cover with the balance gears 'hanging' then you have it assembled correctly?
Old 02-09-08, 04:12 AM
31YTech's Avatar
hannibal,
There is a process for timing these balance gears that MUST be followed.
I have to get to work at this moment but will post the proper timing procedure later today if nobody else does.
Old 02-09-08, 01:38 PM
31YTech's Avatar
I use the shank of a couple of drill bits for locating pins.
Good Luck
Old 02-09-08, 02:07 PM
H
THANK YOU!! exactly what I was looking for
Old 02-09-08, 04:13 PM
cheese's Avatar
Received 31 Votes on 26 Posts
Uh-oh....I goofed...
Instead of going by the model#, I assumed you were talking about a 11hp vertical engine. Thank you 31YTech for catching this!
I editied my first reply to avoid future confusion.
Old 02-09-08, 05:22 PM
31YTech's Avatar
No problem cheese.....
Old 02-10-08, 07:02 AM
L
A little off-topic, but I have never seen a single cyl engine with counterweights.. Why is this? What's the purpose?
Old 02-10-08, 07:58 AM
CAMINO KID's Avatar
There are balance counterweights in Kohler and Briggs engines. They have been used for years to help remove the vibration of a single cylinder. I believe Kohler used them about the earliest of the manufacturers. Radio just reported a wind chill of -51 here today. No shop work, too cold.
