NY
02-09-08, 02:01 PM
john deere surge where nothing will affect it until it dies
i have a john deere trs 27 i sprayed carb and choke cleaner in it and blew it out with compressed air now i went to start it up the other day and it starts up one pull and it will run really crappy like spurts then it will surge absolutly crazy until it dies and nothing changes the surge no adjustments i was given this snowblower so i dont have any manuals or anything for it
FL
02-09-08, 03:20 PM
There should be a decal on the flywheel cover with a model and spec number on it.
Since you say it's a Tecumseh. You may want to check the bowl nut and make sure all ports are open, It is also the main jet
I borrowed this pic from one of geogrubb's post, I hope he doesn't mind....
Non-US
02-09-08, 06:10 PM
It almost sounds like you will need to fully dissassemble the carb, soak in a bath type cleaner overnight, rinse with a spray type cleaner & blow out ALL the holes with compressed air. Install a carb kit with a new float & adjust the level.(IF this is typical 4 stroke Techeumseh,) Give us engine numbers & we can be more help!!! Good Luck, Roger
