Yardworks snowblower won't move
I'm having trouble with my Yardworks snowblower. (Extreme Auger, 10.5hp, 29") Putting the machine in any gear gives the same result: nothing. It just won't move, tires won't move, even manually. I'm pretty sure its not a worn band or wheel... Hoping someone has some suggestions.
Thanks Roger.. I have done all that stuff,...and nothing is dusty, rusty, or dried up that isn't supposed to be. Could it have something to do with the bearings? Do these machines lock up if something breaks in or around the shaft that the wheels are attached to?
I have a long driveway so getting into town on a snowy day to get it fixed will take a while, so I was hoping to be able to do it myself.
Anyway, thanks for the comments.., Michelle.
As far as I know, Yardman, Yardworks, and Yard machines all belong to the same company.. MTD. But I think this one is also called Yard machines. I'll have to get the serial number.
Check out this post, Puey gave some information towards the end that may be relevant, as I suspected it was an MTD.
http://forum.doityourself.com/showth...t=wheels+stuck
I had the same problem today. There should be a small piece of metal that looks like a 1/2 moon thats suppose to slip into the shaft and it connects the shaft to the sprocket. Hope this will help you..
Maybe this might be the answer ...
The other day my father was wanting to bring out his Yardworks snow blower but the wheels were locked.
I found that the cable needed to be tightened that goes from the hand lever to the transmission. There is a small threaded shaft just under the handle with a lock nut. The nut had loosened thereby giving to much slack in the cable. I tightened the cable and firmly tightened the lock nut .. and everything is working fine now.
Hope this little fix may help someone with there machine.
