Head bolt torque
Old 02-16-08, 01:23 PM
Head bolt torque
Could someone tell me the head bolt torque on a Briggs OHV model-31Q777. The best I could find is 165 in-lbs or 13.75 ft-lbs but this doesn't really seem to be enough!
Old 02-16-08, 01:33 PM
A
My chart show 220 inch lbs for this series engine.
Old 02-16-08, 02:18 PM
Thanks for the reply AA.
Old 02-16-08, 06:42 PM
Let me ask you another question- I am replacing the head gasket on this engine, and I noticed the exhaust push rod comes up approx 1/4" but the intake push rod comes up approx 1/8''. Is this normal?
Old 02-16-08, 09:17 PM
cheese's Avatar
Received 31 Votes on 26 Posts
No, it should move more than 1/8 inch. It should be about the same as the exhaust.
Old 02-17-08, 03:37 AM
Wink
Thanks Cheese. I think I'm going to have to disassemble the engine so I can find my trouble, The engine was hard to turn over however it would start and run O.K.. It's a model 31Q777 B&S on a cub cadet. It was blowing oil all over and it had some positive pressure on the crankcase. I pulled the head off and found the head gasket in bad shape between the cylinder ond the valve cavity. I also replaced the breather reed valve (which didn't seem bad).
