tecumseh
Old 02-17-08, 08:04 AM
G
tecumseh
Hi,
sorry if my english is not perfect
my tecumseh engine run badly I can see fire in the muffler
I try to ajust the carb but son't know at all what screw do what, it's like to run a bit better because I can have it run at slow now but still have fire in the muffler when it run full gaz and get some oiled gaz coming from carb I think because it go on the same side a the carb. I see it after I finish blowing the snow. what can cause that ? to high fast throttle?
what is the screw under the carb ?
and there is 2 other we can ajust.
can I see a oic of the carb with explication of the screw somewhere
thankx
Old 02-17-08, 11:25 AM
G
You can download service manual for your engine from following:
http://www.cpdonline.com/692509.pdf
3 to 11 HP 4 cycle L Head
The screw on bottom is main jet, turn out 1 1/2 turns
and one on side just above bowl is idle jet, turn out 1 turn.
the other on top is just to set the idle speed.
hope this helps,
thanks,
Old 02-17-08, 02:42 PM
G
O.k I will try it
Thank you
I turn from where completely close or open ?
Old 02-17-08, 06:26 PM
G
The main and idle jets are to be lightly seated(closed), finger snug, don't force hard, then turn out respective number of turns.
thanks,
