Older Craftsman Riding mower ??
Old 02-17-08, 10:26 AM
D
A friend just gave me a Craftsman riding mower (model # 502-255040) 10HP 30” cut after replacing the ignition it seems to run fine with a couple of exceptions. When I turn the key to the off position the engine doesn’t shut-off and the brakes don’t work at all … any help on this one???
Old 02-17-08, 11:41 AM
31YTech's Avatar
The yellow is the kill wire, Make sure it's hooked at the engine and has no breaks in it up to the ignition switch.
On the left side top of the transaxle (sitting on the seat) you will see a arm with a rod ran through a adjuster. This is the brake rod, Removing this adjuster from the arm and backing it off the rod a couple turns at a time will tighten the brake if the lining isn't worn out.
Good Luck
Old 02-17-08, 11:53 AM
D
Thanks
31YTECH,
Thanks for the info...I'll try it and post the results.
Old 02-17-08, 12:55 PM
Sears still shows parts for this unit. Call Sears & order a owners manual-it has all the info you need.
I have this unit-runs fine after 7 years
Old 02-17-08, 01:00 PM
D
I ordered some parts today but the manual has been discontinued ... if I'm looking at it right
Old 02-17-08, 02:48 PM
Did you call Sears??????????
If you can't get cat--I will e-mail you most important part of cat.
Send e-mail in private message
Old 02-17-08, 02:52 PM
D
no but plan to tomorrow...thanks for the info.
Old 02-17-08, 05:15 PM
I found a Sears manual for you. This manual is pdf.
Go to Sears website--parts--type model # 536.270112
You have to register
First box type: rear engine rider
make a screen name & register w/ password.
This model is identical to yours
Have fun............
Old 02-18-08, 05:29 PM
C
same thing
yeah i got a old craftsman too im looking to turn into a dragger im hoping to school the junior dragsters that have all the money and what not im on a budget like 100 and i have a 12.5 and im getting a peerless 600 3 speed from a fella i know ps i live in cape breton canada and theres no such thing as lawnmower racing up here so i have to customize stock parts any help would be greatly appreciated
Old 02-18-08, 06:18 PM
@Craftsman 12HP
Sorry, I cut grass w/ riding mower-I'm not into draggers
Old 02-18-08, 06:22 PM
G
Craftsman12hp
Might would have been better if you had posted a new thread of your own. I'm not sure what answers you're after, but doesn't sound like Desi's.
thanks,
Old 02-19-08, 12:06 PM
C
thanks,
Thats true ,,,,,,,,,,,,,,,,,,,,
