Mantis Tiller run problem
Old 02-21-08, 08:05 PM
G
I have owned a mantis tiller for ten plus years and it is on its 4th set of tines . I purchased a used tiller which was not in running condition , as backup.
I did the usual cleanup, cleaned tank, gas lines and throughly flushed the carburetor. It starts on full choke and will run for a few seconds . At times it will run on full throttle and one quarter choke but quit at any other speed. I took the carburetor off, soaked it in carburetor cleaner and installed a kit. It does essentially the same as before.Help.
Old 02-21-08, 08:31 PM
cheese's Avatar
Received 30 Votes on 25 Posts
Still sounds like a carb problem. Did you verify that all the passages in the carb are clear?
Old 02-22-08, 12:07 AM
F
Received 1 Vote on 1 Post
what kind of kit did you install and what did you replace.
Old 02-22-08, 03:29 AM
G
Also, what is the make and model no of the carb and what was the part no of the kit you installed ??
thanks,
