craftsman mower
Old 02-28-08, 03:00 PM
jedlin13's Avatar
craftsman mower
Hello everyone, I hope ya'll can help me. I was mowing my yard with a friends craftsman riding mower. When it just coasted to a stop. Motor still running and everything. It will start up fine but will not move unless being pushed. I tried going to that sears3.com site but apparently the site doesn't work. I have the model number. I am trying to see a diagram of everything and see if something is broke or missing. I really need to get this fixed quickly and as cheap as possible before our friendship goes bad.
Old 02-28-08, 03:07 PM
A
Try this:
www.searspartsdirect.com
you will need your model number.
indypower500's Avatar
Please post your model number
Old 02-28-08, 03:19 PM
jedlin13's Avatar
model number 917. 271910
Old 02-28-08, 03:22 PM
jedlin13's Avatar
Thats that same site. I click on part# and nothing happens. Am I not using the site properly?
Old 02-28-08, 03:57 PM
Enter the model # where it says ---model#--- not part#, you can then get diagrams of the mower, 1st thing to check is drive belt.
Old 02-28-08, 04:08 PM
jedlin13's Avatar
I must be crazy cause thats the same site i dont see anywhere to enter a model number. all that site does is tell me where to find model number
Old 02-28-08, 04:10 PM
31YTech's Avatar
Then raise the rear tires off the ground, With the trans in gear grab both rear tires and try spinning them at the same time in the same direction.
If they spin the opening in the 'E' clip holding the wheel on could have aligned with the axle key slot and let the key walk out, I have seen this happen a few times.
Could also be broken shift keys in the trans....
Good Luck
Old 02-28-08, 05:30 PM
jedlin13's Avatar
I will check that out either tommorow after work or saturday. I just hope the problem is cheap to fix and easy to fix.
Old 02-28-08, 07:14 PM
A
I don't quite know what your doing, but I found your unit on that site ok. Just put in your model number in the first box where it says search by model number "enter model number" and click search. Then click on whatever sub component you want to look at.
Old 02-28-08, 07:19 PM
jedlin13's Avatar
ok i tried again. whats the site address? maybe i got it wrong
Old 02-28-08, 07:20 PM
A
http://www.searspartsdirect.com
Old 02-28-08, 07:35 PM
jedlin13's Avatar
i think i have it its a pdf file of the owners manual. is that what you was looking at? i had to register and get a screen name in order to see it.
Old 02-28-08, 07:49 PM
A
No, I saw that but I did not go there.
When the page loads the upper most box on the right hand side of the screen reads
Search by model number
and inside the box it has printed
Enter model number
Click inside this box and enter your model number, then the next page that loads will have a list of sub components in the middle left side of the page that you can select and view.
Old 02-28-08, 08:28 PM
jedlin13's Avatar
when i go to sears partsdirect there is no box in the right corner. heres the site i get when i clicked the link in prevoius post below. http://www.searspartsdirect.com/part...t/index.action
Old 02-28-08, 09:05 PM
A
Maybe you need to try refreshing the page or clearing your browser history, I don't know why this site does not show the box in the upper right hand corner. I clicked on the link in your post and it popped right up on my browser.
I wish I could paste a copy of my browser screen in here to show you what I am talking about.
Old 02-29-08, 03:59 AM
31YTech's Avatar
Here is a pic of the drive system for that unit;
Old 02-29-08, 05:33 AM
G
Unhappy
http://www3.sears.com
Sears upgraded to a new parts page at the beginning of the month. It's extremely slow for dial-up users lilke myself. It seems to load the parts page in sections.
You have to wait for the word 'search' to appear in it's box in the right hand corner to display models or parts.
they've enhanced it to the point of difficult usability for dialups.
Old 02-29-08, 01:36 PM
jedlin13's Avatar
that diagram helps i'm gonna try to make it bigger. thank you. We got that high speed internet deal here, cable i guess it is. I'm gonna mess around with it tommorow. Its supposed to be nice here so i'm gonna get some trees and fenceline cut and see what i can do with this mower.
