long term storage of B&S 12.5 hp engine
2944daniels's Avatar
03-02-08, 04:51 AM   #1
hello and thanks for responding. i have a B&S 12.5 ic engine that i would like to put in storage for a spare engine. i hope this will be long term storage! the motor runs fine. let's have a good day.....
GlenM's Avatar
OK
03-02-08, 06:00 AM   #2
I'm assuming you're wanting tips on how to store. Run engine until warm, empty gas tank and run it dry, drain and replace with fresh oil, remove/dry/reinstall carb bowl. Remove plug, squirt at least a teaspoon of oil in cylinder, turn engine several times to coat cylinder, reinstall plug. Put it in a box or enclose in trash bag to keep critters away.
jedlin13's Avatar
KY
03-02-08, 07:40 AM   #3
couldnt agree more
bontai Joe's Avatar
PA
03-02-08, 08:03 AM   #4
Excellent advise above. Only thing I could add is to put a dissicant (moisture absorbant) in the bag before sealing. You know those little bags of pellets inside boxes when you open them up? That will absorb moisture inside the container you place the engine in. I'd use a heavy bag to be as moisture proof as possible.
makeitso's Avatar
CAL
03-02-08, 08:34 AM   #5
The only thing I would add is to turn the enging until you feel resistance of compression after you replace the plug when you put the oil in the cylinder. When you store it you want it to be on the compression stroke to prevent anything from having a chance to enter the cylinder.
GlenM's Avatar
OK
03-02-08, 10:26 AM   #6
With these add'l good ideas, you could put this engine in your will.
