checking engine
Old 03-04-08, 09:31 AM
checking engine
Thanks everyone for all the help with my briggs and Tecumseh engines. I have another question. I have a Briggs engine with electric start. Its off machine so it has no battery hooked up to it. Is it possible to start the machine with a charger? If so, how.Don't want to get shocked.
Old 03-04-08, 03:33 PM
31YTech's Avatar
Hate to inform you of this....But, The "machine" won't start without a engine on it.
Now, If you want to start the engine use the battery thats in the machine and a set of jumper cables. Put the positive lead on the starter post and just touch the negative to one of the engine mount ears on the pan (sump).
Doing this will throw a few sparks but wont shock you,
It's not a good idea to try jumping with a charger without a battery.
Old 03-05-08, 05:07 AM
I meant to say start the engine. I don't have the machine. I did like you said . It tries to start, but stops. I took the spark plug out and tried to turn it by hand,very hard. Put some oil in spark plug hole. Turns a little more than before, but still hard.
Old 03-05-08, 03:18 PM
31YTech's Avatar
Is this the same engine that you replaced the governor crank in ?
If not tell a little history on it and post some numbers.
Old 03-06-08, 05:55 AM
No, its not the same engine. It's a Briggs and Stratton I/C 10.5 HP, model #28B700, type#1025-E1.Single cylinder,air cooled engine.The engine came off of a sander.
Old 03-06-08, 02:25 PM
when turning the flywheel by hand, can hear a grinding noise comoing from underneath. Sounds like soomething might have broken.
Old 03-06-08, 03:08 PM
31YTech's Avatar
First make sure the coil isn't rubbing on the flywheel, If not then it sounds like you need to perform a tear-down inspection to find the problem.
Good Luck
Old 03-06-08, 04:40 PM
Take the flywheel off and check out the alternator coil and magnets under the flywheel for a problem. May have something stuck to one of the magnets or a loose alternator. Since it has an electric start it probably has an alternator. Just a thought anyways.
Old 03-11-08, 09:26 AM
I am having the darndest time trying to remove the bolt holding the flywheel.Already broke one socket. wd-40, heat nothing works. Any suggestions beside dynamite?
Old 03-11-08, 10:43 AM
I use the air impact tool, if it's just a nut holding it on.
Old 03-11-08, 05:11 PM
31YTech's Avatar
Throw it in your car/truck and run it by a auto repair shop, Let them zap it off with a impact wrench.....
Old 03-19-08, 09:43 AM
Removed the flywheel,magnets were damaged, the alternator was also damaged.Also noticed a small hole on top of the crankcase. Can that be repaired or not?
Old 03-19-08, 10:44 AM
How did magnets and alternator get damaged and hole in top ? Must've used a tire tool to get flywheel off. or,
may have thrown a rod, I would take head off see what happens when you turn the flywheel.
Old 03-19-08, 12:20 PM
The hole came from using the flywheel puller. Must have screwed the bolts down to far. Can the small hole be filled?
Old 03-19-08, 04:49 PM
31YTech's Avatar
You didn't read this from me....
Cut a little patch piece from a aluminum can slightly larger than the hole, Ruff the area around the hole with course emory paper and bond the patch over the hole with JB-Weld.
Old 03-20-08, 05:37 AM
Thanks, I'll give it a try.
