broken lower handle
Old 03-06-08, 08:34 AM
broken lower handle
I have a toro S-200 electric start snowblower model 38130 serial 0334425 the lowerhandle is broken. its broken below where the upper and lower meet. I can't find a part number for the lower handle. they only sell the upper.is it possible to get a lower handle or can it be welded.its a clean break
Old 03-06-08, 12:14 PM
Piece of light sheet metal--wrap around break & pop rivet it.
Don't waste money on welding for an S-200.
or a piece of wood dowling-jamb broken pieces over it & put screws thru metal to wood. Lots of good Rube Goldberg ideas.......................
Old 03-06-08, 01:14 PM
The lower handel is part number 49-1390 About $40.00
AJ
Old 03-07-08, 10:06 AM
thanks aj. sense its part of the frame i will have to re-assemble the snowblower.
right below where the upper bolts to the lower is where it broke
Old 03-07-08, 10:48 AM
I took my S-200 apart last week--hope your family has a good set of ear plugs.
If you have to take off back panel, take careful note of how it goes back together. Also,remove screw holding carb. cable to back panel-try not to take cable off carb.
It's a good idea to put masking tape around screws & bolts
showing location of same.
I know you will enjoy......................
Old 03-07-08, 11:41 AM
whats your problem
Old 03-07-08, 12:30 PM
It's called a recoil starter cord
Plus the fact my unit is about 29 years old & is almost as tired as I am
By the way, when I shut down my PC, I get all these stupid screens saying this or that-I have to click OK-- doesn't bother PC, just me...........
