Help with Homelite 50
Old 03-10-08, 03:34 AM
I need help rewinding the starter rope of a 50 Homelite. Is there anyone that can help me or anyone where I can look?
Thanks
Bruce
Old 03-10-08, 11:47 PM
cheese's Avatar
Received 17 Votes on 15 Posts
I'm not sure what a 50 homelite is, but generally you'd wind up the spool, tie on the pull rope, and let it wind the rope onto the spool.
Old 03-11-08, 08:32 AM
What is a Homelite 50...........??
Old 03-11-08, 10:54 AM
Is it a mini bike ??
Old 03-15-08, 03:36 AM
First I made a typing error It's a Homelite 150 Chainsaw.
The spring within the case. but case has been removed from the chainsaw. After the case is replace on the saw how
can it be rewound?
Old 03-15-08, 09:28 PM
cheese's Avatar
You take it off to wind it. Wind it up until it stops turning, then back it up until the hole in the rope spool lines up with the hole in the housing. While holding it from turning, insert the new rope through the holes, fasten the end of the rope at the spool and the handle on the other end of the rope, and let the spool go. When you let it go, it will wind up the rope. If it didn't wind it all up, move the handle closer, then reinstall the assembly.
