Spark plug cover question
Old 03-12-08, 05:37 AM
Last fall could not turn over my wacker. Attempted to change spark plug. When i removed cover the wire coil came off the cover and was attached to plug. Is there any way to reconnect this coil or do I need a new cover? If I do need a new cover is this a simple fix?
Thanks
Bails
Old 03-12-08, 06:32 AM
If you're talking about the spark plug boot coming off the spark plug wire, oftentimes you can just firmly jam the boot back onto the wire.
thanks,
Old 03-12-08, 11:44 AM
thanks,
Doesn't this wire connect to another wire within a sealed casing? How will I know if the two wires are connected?
Thanks
Old 03-12-08, 12:40 PM
What's the make and model of your unit ?
thanks,
Old 03-12-08, 06:16 PM
cheese's Avatar
Received 17 Votes on 15 Posts
Push the rubber boot back up the plug wire so the wire end is sticking out. You'll see a smal hole where the little wire clip was inserted into the plug wire. Re-insert it there, bending it if necessary, and then slide the boot back over the entire works. The boot keeps it held together.
