Briggs & Straton
jwbond's Avatar
TN
03-18-08, 03:59 PM   #1
Briggs & Straton
I need some help.
I have a 2002 sears DYT4000 w/ briggs & straton 21 OHV Intek twin, 40777-0121E4 engine.
Recently i was mowing and something broke inside and knocked a hole in the motor.
I spoke to sears about replacing the motor and the estimate was like 2,400, can i purchase this motor from someone other than sears? What information is needed from the motor to insure I order the correct model.
Any help will be much appreciated.
smallengineguy's Avatar
MA
03-18-08, 04:32 PM   #2
40777-0121E4 , these numbers are all you need but you appear to missing a digit in the --40777-- which is the model#,
You can try these guys, prices are very competitive.
http://www.tulsaenginewarehouse.com/
31YTech's Avatar
FL
03-18-08, 04:46 PM   #3
I took a guess that you left a seven off the number you posted so I added one and this is what I found;
Those numbers on my dealer's only site show the proper replacement engine is model #407777 type #0027, Your engine is no longer built and the direct replacement is not either.
I found this one you may want to check into;
http://www.tulsaenginewarehouse.com/...rt/407700.html
Or you can contact this place with your numbers and see if they have anything for a replacement;
http://www.smallenginewarehouse.com/...upplier=Briggs
Good Luck
puey61's Avatar
NY
03-20-08, 02:32 PM   #4
You should have either a 405777 or a 407777 with a 0121 type number. In either case a shortblock is available for $1021.65 plus backfreight and truck charges and is Briggs part number 698172. A replacement engine is also available for either model number for $1391.10 plus freight and truck charges and is part number 44K777-0027. You do the labor and save yourself $1300-$900! I'd go with the engine since there is no change-over time involved as there is with a shortblock.
