seized engine in pressure washer
Old 03-28-08, 04:55 PM
I have (had) a 6.0 hp briggs pressure washer that I borrowed from my father in law. I cranked it and about 5 minutes later it seized up on me. I heard a loud "clank" noise then nothing. I went to check the dipstick and smoke was coming from the oil resevoir and there was no oil. Did I just buy a new pressure washer or can this one be repaired. It's a model that only costs about $300 new. Thanks.
Old 03-28-08, 05:15 PM
31YTech's Avatar
Looks like you just bought a new washer, By the time you were to repair this one (if possible) you wouldn't be far from the new one.
If you only ran it 5 mins. your father in-law done most of the damage himself before you got it, Split the cost with him and call it a day...
Old 03-30-08, 07:45 PM
bontai Joe's Avatar
You just paid the tuition to learn that you should never ever start an air cooled engine without pulling the dipstick and checking the oil. Most small engines run on a quart or less of oil and are very sensitive to low oil levels. Make it a habit to ALWAYS check the oil before starting a motor, it only takes 10 seconds.
