briggs & stratton engine
Old 04-07-08, 05:21 AM
model 193707
type 4025-01
code 90102310
I have the above, have put new rings on piston. But do-not know which postion to put the valve cam.
Can some kind person tell me which way it is.or point me to a wed site.
sep. fr
Old 04-07-08, 06:21 AM
puey61's Avatar
I'm not sure what you mean by valve cam so if it is the camshaft you are referring to then you must line up the two match marks - one on the crankshaft gear and one on the cam gear - in order to time the valve train correctly.
Old 04-07-08, 06:29 AM
Thanking you
There is a small hole on the cam gear,is it the same on the crankshaft?
Old 04-07-08, 11:25 PM
cheese's Avatar
There should be a tiny dot on the camshaft gear tooth that lines up with the tiny line on the gear of the crankshaft.
