Troy-Bilt Pressure washer pump
Received 0 Votes
Have a Troy-Bilt Pressure washer, 020209, SJV 3G27-1 pump. No high pressure, only water flow through pressure. Was working fine, stopped high pressure during th job I was on. Any ideas to fix other than a new pump?
You might try removing the unloader valve, as this is a common place for pump problems like the one you describe. If you can get it out, clean it and lube it, replace the oring(s) and clean the bore it fits into. This is probably where the problem lies, if you can gain access to the valve and remove it.
