Husqvarna Riding Mower - Broken?
Old 04-23-08, 05:00 AM
Last night I changed the oil on my mower and fired it up, it ran for about 10 mins without problem. Than it just stopped, I thought it stalled and I walked over and the think simply won't turn over, when I turn the ignition I see no movement on the battery meter. Of course it does have juice because 1) it just started and 2) I measure it with my multimeter. I can't find power going to the starter. So I'm trying to figure out what it could be, here's an electrical parts list from the manual if that helps:
KEY PART
NO. NO. DESCRIPTION
1 532 14 49-27 Battery
2 874 76 04-12 Bolt Hex Hd 1/4-20 unc x 3/4
8 532 18 64-91 Box Battery
16 532 17 61-38 Switch Interlock Push-In
21 532 17 56-88 Harness Asm Light W/4152j
22 532 00 41-52 Bulb Light #1156
24 532 12 47-80 Cable Battery 6 Ga. 11" red
25 532 14 61-48 Cable Battery 6 Ga. 22" red w/16 wire
26 532 17 51-58 Fuse 20 AMP
27 873 51 04-00 Nut Keps Hex 1/4-20 unc
28 532 14 54-91 Cable Ground black
29 532 12 13-05 Switch Plunger Nc Gray
30 532 17 55-66 Switch Ign
33 532 14 04-01 Key Ign Molded Generic
40 532 17 97-20 Harness Ign.
41 871 11 04-08 Bolt Blk Fin Hex 1/4 - 20 x 1/2
42 532 13 15-63 Cover Terminal Red
43 532 17 88-61 Solenoid
48 532 14 08-44 Adapter Ammeter Rectangular
52 532 14 19-40 Protection Wire Loop
55 817 49 05-08 Screw 5/16-18 x 1/2
90 532 18 04-49 Cover Terminal Battery
91 532 19 02-70 Strap Battery Mount Front
My mower is a Husqvarna YTH150,
Any help is greatly appreciated!
Thanks,
Matt
Old 04-23-08, 11:31 PM
cheese's Avatar
I'd start by checking the fuse. It is usually near the solenoid inline with a red wire coming from the battery calbe side of the solenoid.
Old 04-24-08, 04:06 AM
Fixed!
It was the fuse after all, I checked it last night after work and it was fried. Thanks!
Matt
Old 04-25-08, 12:06 AM
cheese's Avatar
Anytime! Glad I could help. The fuse can sometimes blow for no obvious reason... and you can put in another and never have another problem with it. However, if it continues to blow, there is a problem that needs to be tracked down and fixed.
