lawnmower problems (engine dies)
Old 04-25-08, 09:50 AM
i was just mowing with a white lawnmower and all at once it died. I raised the blades back up and it started back. I engaged the blades again and and died. It will run and as soon as I engage the blades it dies. It does not mater if it is in park or frontwards or backing up. Can someone help me please
Old 04-25-08, 05:02 PM
31YTech's Avatar
Check the seat switch and make SURE that the wire harness plug is on tight, Check the plug/switch contacts. If both of these are fine check the seat switch with a multimeter and make sure it's opening/closing when pushed.
Good Luck
Trackbacks are On
Pingbacks are On
Refbacks are On
