Problems starting a Yard Machines weed trimmer
Old 04-28-08, 08:48 AM
I have a Yard Machines model Y28 weed trimmer made by MTD. I bought it last year at my local Menard's store. I used it for a while and it always seemed a bit hard to pull and hard to start. My brother borrowed it and then later in the season after the droughts had abated I picked it up to use again. My brother then informed me that he hadn't been able to start it for a while and that it needed fixed. I took it home and tried to start it. It seemed even harder to pull than before and didn't seem to be getting fire. I borrowed a trimmer and set it aside. This spring I started looking it over. It gets gas ( spark plugs wet with fuel when I pull it). The plug doesn't seem to be getting fire, even when grounded. However, the plug doesn't seem to be broken or cracked and while a little black from use it doesn't seem to be fouled out either. I checked the gap and it's fine. I checked as many of the electrical connections as I could and nothing seems out of place or broken, to break the circuit. I just can't get it to start. Is there any reason why I shouldn't get fire other than the plug or the wire connections? Does it have anything to do with why it pulls so GD hard? Any help is greatly appreciated.
Old 04-29-08, 09:29 AM
I'm still hoping for some help with this. So, BTT.
Old 04-29-08, 06:09 PM
puey61's Avatar
The hard pulling could be related to the apparent no-spark problem but it's not likely unless the ignition coil loosened and is making contact with the flywheel. You say that you bought this unit last year. The typical MTD handheld product warranty is one year. Are you within the warranty period? If so, take it to your local MTD service shop for possible warranty consideration. The hard pulling could also be a seizing engine or just the foolish pull assist that most new MTD products incorporate. As for the spark, have you checked for spark at the spark plug by grounding the plug, pulling the engine over and observing for spark at the electrode?
Old 04-30-08, 08:13 AM
I checked the spark plug, by grounding it and pulling, and no spark. It also pulls very easy when the plug is out. I can't find my reciept, but I think that I'm probably outside the warranty period. Could the ignition module possibly be bad?
Old 05-01-08, 01:03 PM
Still looking for help on this, BTT.
Old 05-01-08, 03:36 PM
hopkinsr2's Avatar
You are grounding the plug to the engine & not just a part of the plastic cover??Just to be sure "cus there is a lot of plastic on these. Take the muffler off & look @ the inside of the cylinder & piston (turn the crankshaft slowly to see all of it) incase it started to sieze @ one time....Roger
Old 05-02-08, 08:05 AM
I've grounded it against the block, a screwdriver, and my fingers. Nothing on any of those attempts. I also checked the cylinder and it seems to be moving up and down just fine.
Old 05-05-08, 07:50 AM
I still can't get it to start. I still can't find my reciept to check for warranty. It looks like I'm screwed. I really hate that, since I only used it a few times and and it's somewhere around a year old. It's really crappy that it's already useless, if I can't start it. I really want to figure this out and fix it instead of buying another, especially since I can't afford another right now. I really wish I could habe shelled out a little more and gotten a better made trimmer.
Trackbacks are On
Pingbacks are On
Refbacks are On
