Toro Mower Blade Won't Turn
I have a Toro mower with a Tecumseh motor. When I was doing my Spring tune-up, I noticed the blade would barely turn. So I kept pulling off parts until I found the problem and it seems the piston is not sliding in the cylinder. I pulled the piston out, there were a few scrap marks on the piston side and very little scoring in the cylinder. Rings looked good.
Is this repairable or is this time to buy a new mower? Can I hone out the cylinder until the piston slides freely?
Thanks for your help.
Maybe this is an obvious question, but when you tore down the engine, was there any oil in the crankcase? Or were the cooling fins totally packed with debris? Sounds like it either ran low on oil or overheated, or both.
The crackcase did have oil in it, but I did notice specs of metal in the oil. Cooling fins were clean, but the mower could have overheated and/or been low on oil. Is it possible it got hot and the cylinder warped, which is why the piston is not moving freely?
