1984 toro riding mower
Need information on troubleshooting transmition. Checked belts and and chain both ok. Transmition seems to be turning . Can see bearing end turning but, shaft has no forward or reverse movement. Is it possible something out of adjustment ?
The pulley is turning? Are the axle keys missing? What happened, it just stopped working one day? Or did you pull a wheel off to get it repaired, etc...?
toro riding mower
I put it in reverse and backed up normaly. Put in forward gear and no movement. Brake is off. No movement forward or reverse no sounds or vibration. Pullys donot turn. thanks for any help.
