Deere F525 IGNITION PROBLEM
Old 05-13-08, 09:58 PM
I have a 1996 F 525 and up untill now has never given a bit of trouble. The other day it was running fine and than all of a sudden shut down and wouldn't restart. A few minutes of checking showes that there was no spark. Sparkplug checked out good so I'm guessing coil not very familiar with kawasaki engines. Any ideas
Thanks
Old 05-13-08, 11:35 PM
cheese's Avatar
What engine is on it? 17hp kawasaki single cylinder air cooled?
Old 05-14-08, 06:33 PM
Hello Cheese,
Yes that's exactly what it has in it, 17 horse power single cylinder air cooled Kawasaki. The decal on the engine says PA540A and from what I could gather from a DEERE website I think the numbers after that are FC540V and the ID number is MOF525A160279.
Thanks Cheese
Old 05-15-08, 12:16 AM
cheese's Avatar
Did you try a brand new spark plug?
If so, and still no spark, unplug the kill wire from the white wire near where it plugs into the igniter ont he side of the engine. Check for spark with this disconnected. If there is spark, you have a problem with the wiring or safety system of the mower. If there is no spark still, then you have a bad coil or igniter. I see a lot more kawasaki igniter failures than coil failures. If you do wind up finding a bad igniter, don't go buy a new one from Deere. Buy a genuine Kawasaki igniter. The deere ones are commonly bad right out of the bag, or shrotly thereafter, and they don't take refunds on electrical parts.
Old 05-17-08, 09:56 AM
Hi Cheese
Tried the new plug and nothing. I will try the igniter next.
Thanks for your help, I'll let you know what happens
Roc
Old 05-30-08, 08:38 AM
Im having the same problem, just looked at it yesterday and no spark. I am going to perform the test you suggested below. I'll let you know what happens.
Also, im doing this repair for my father and do not know much about the mower, the battery died and he jumped it with his truck for like an hour, but it started after he did that. The next time he had to start it though, no spark...
