carb help
pontiac467's Avatar
IL
05-14-08, 02:06 PM   #1
carb help
i got a briggs and stratton motor im working on model number 350447. does anyone know what the top vaccum line goes to thats on the top of the carb. There is only 2 spots were hose can go on the carb and one is the fuel inlet, the mower runs fine until you try to plug the other line then it dies. I know it has to go to something because otherwise i would think stuff would get into the carb when you are mowing. Thanks for the help
the_tow_guy's Avatar
FL
05-14-08, 03:57 PM   #2
Primer bulb maybe. Just a wild guess.
Measure it with a micrometer; cut it with an ax.
pontiac467's Avatar
IL
05-14-08, 05:51 PM   #3
I tried to add gas to the line when its running and it wants to die because of too much fuel(running rich) I think thats what a primer bulb would do right? i dont know much about mowers. thanks again
31YTech's Avatar
FL
05-14-08, 06:49 PM   #4
That's the float bowl vent, There is nothing supposed to go to it. If it would make you feel better put a piece of hose on it and let it hang down open.
