Briggs & Stratton Oil Gard question
Old 05-15-08, 09:45 AM
Question Briggs & Stratton Oil Gard question
I own a Generac SVP 5000 series generator that has a Briggs & Stratton Industrial Plus model 196412 type 012901 code 9702191A engine. The engine wouldn't start this month and I checked for spark and there was none. The oil level is ok and the spark plug is new. I disconnected the lead to the Oil Gard module and the spark returned. I started the engine and reattached the wire to the oil gard module and it stayed running . It now starts with no problems. Can someone explain how the oil gard module works? Since this is a splash oil system I figure that it is a oil level switch of some kind. I checked the wire with an ohm meter and physically removed it to check for worn or missing insulation and it is ok. Does this unit complete a ground to enable the ignition or does it complete a ground to disable the ignition.
Thanks
Wayne
Old 05-15-08, 08:15 PM
31YTech's Avatar
Hey Wayne,
This should cover your question;
It's possible the float stuck ? If problems persist the module can be removed and washed in mineral spirits then lightly blown out, If that doesn't help replace it.
Cya
Old 05-16-08, 06:35 AM
That makes sense to me now. The output terminal showed continuity to ground when I checked it. I think I will clean it with mineral spirits now and monitor it with my monthly start up schedule. Thanks for your help.
Wayne
