governer on new tecumseh motor
shaker843's Avatar
NC
05-16-08, 07:31 AM   #1
i just bought a new motor for my go cart and when i installed everything it will idle but wont rev up. i can watch the throttle move thru the full swing but it never moves the governer spring. it looks like the gov spring is to long it just starts to grab at the end of throttle movement. i can manually move the govener and get it to rev up. not sure if i have to bend the spring or adjust anything. it looks like someone bent the spring on the old motor. it is a 6.0 hp powersport motor. model ohh60. any help would be great.
geogrubb's Avatar
MO
05-16-08, 03:12 PM   #2
I think the info you need is the manual at the link below. Have a good one. Geo
http://www.cpdonline.com/695244a.pdf
31YTech's Avatar
FL
05-16-08, 04:08 PM   #3
You can bend the tang the spring hooks to on the throttle control assembly to gain more RPM. But, It sounds like you don't have your throttle cable mounted/adjusted properly.....
