1986 Simplicity 12hp Rider Help Will Not Crank Over
TTIPPY's Avatar
NH
05-19-08, 06:03 AM   #1
Iv'e Got A 12hp 1986 Simplicity Riding Mower.it Will
Not Crank Over.i Replaced The Solinoid And The Battery.i Can Jump The Solonoid And It Cranks Over
But Will Not Start. It Does Have Some King Of Switch
In The Seat.it Will Not Start Unless You Are Sitting
On The Seat.i Took A Paper Clip And Made The Connection
For The Switch And Still No Crank.any Ideas?:
cheese's Avatar
GA
05-19-08, 11:37 PM   #2
Is the fuse good?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
TTIPPY's Avatar
NH
05-20-08, 04:43 AM   #3
I Cannot Find A Fuse. Do You Now Where I Should Look For It?
cheese's Avatar
GA
05-20-08, 10:58 PM   #4
Follow the positive battery cable to the starter solenoid. From here, there should also be a small red wire coming off the solenoid post. Follow that wire until it gets to the fuse.
God bless!
TTIPPY's Avatar
NH
05-27-08, 06:41 AM   #5
I REPLACED IT AND STILL NO CRANK.
cheese's Avatar
GA
05-28-08, 12:18 AM   #6
Is there power at the fuse?
God bless!
TTIPPY's Avatar
NH
06-20-08, 09:13 AM   #7
Sorry It Took So Long To Get Back. Yes There Is
Power At The Fuse.there Is Power And Ground Everyplace There Should Be That Is Can Tell.should I
Check The Ignition Switch And How Should I Do That
cheese's Avatar
GA
06-21-08, 12:20 AM   #8
Check for power at the small wire plugged onto the solenoid while trying to crank the engine. If there is power there and the solenoid doesn't click, then the solenoid is bad.
God bless!
