Honda HRR 216 Blade Problems
Old 05-19-08, 10:37 PM
G
Hello -
I installed a new Honda HRR 216 Blade and now I am having trouble starting the mower and when it does start it doesn't seem to sound normal. When I take the blade off........it runs fine. I can't figure out what the problem is. Could it be the wrong type of dual blade? Thanks for your help...gipper
Old 05-19-08, 11:07 PM
cheese's Avatar
Received 45 Votes on 40 Posts
How is it hard to start, and what type of sound is it making? Is the blade hitting the deck maybe?
Old 05-21-08, 03:57 PM
G
Question The Belt was off..........
After looking at the blade more closely; I noticed that the belt was not tracking correctly. However, this was one of the problems. Now i have noticed that the blade holder does not firmly attached to the shaft connected to the motor. There are sever grooves inside the blade holder and a groove in the shaft...........does anyone know if there is a piece inside the blade holder or on the shaft that allows the blade holder to firmly attach to the shaft stemming from the motor?
Old 05-21-08, 07:22 PM
G
Thanks for your response Cheese. gipper
thanks for your response cheese. gipper
Old 05-22-08, 01:20 AM
cheese's Avatar
There should be a key that holds the blade adapter from turning on the crankshaft.
