Briggs & Stratton- gushing gas, oil and gas mixed
mailmandave2's Avatar
MA
05-22-08, 03:53 PM   #1
I have a craftsman lawn tractor with a B&S 28U707 engine. It dies whenever able to start. It is gushing gas from the breather tube connected to the air filter base. Also, I removed the oil fill tube to find gas in with the oil.
31YTech's Avatar
FL
05-22-08, 05:33 PM   #2
Sounds like a piece of trash got under the float needle valve or the needle valve is bad or fuel is inside the float. For just a few bucks I replace the float valve when I go into one that's flooding. Check the float by shaking it between your fingers, It fuel is inside you will feel it.
Here's a paste I keep handy;
Take the carb. off then tear it down, Spray carb. & choke cleaner with the straw through ALL ports, passages and jets then blow it out with compressed air if available then re-assemble, Check/clean the fuel tank and flush/replace the fuel hose and install a new fuel filter then change the oil.
Good Luck
