Mcculloch 320
minibiker's Avatar
OR
05-22-08, 04:34 PM   #1
Mcculloch 320
I am using this engine on a pedal bike. Put a sprocket on the clutch and use a chain. but anyway. I cant get it started.
I do have spark and I can tell it does have pretty compression by just pulling but I will test it just incase. The fly wheel has not been removed so the timing should be good. Can anyone think of anything else? I am putting gas in the cylinder and pulling but still no go.
cheese's Avatar
GA
05-23-08, 12:15 AM   #2
Is the chain installed while you're trying to start it?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
minibiker's Avatar
OR
05-23-08, 06:31 AM   #3
No, the clutch isnt installed at the momment. I still need to put braze the sprocket on it. I am going to set the timing a little ealier. I once had a weed wacker engine that would not and after setting the timing earlier it ran good. Also I am thinking of making engine mods. DO you know that WONT put blow the engine.
minibiker's Avatar
OR
05-23-08, 01:28 PM   #4
Ok. I can get it running by pouring gas down the cylinder. It wasnt sucking gas through the gas line so i cleaned the carb. It just wont stay running.
minibiker's Avatar
OR
05-23-08, 02:09 PM   #5
Ok. I fooled around with the High and Low settings on the carbs. Runs ok. Little bit of bogging. I found that they rev pretty dam high also. Is this just me?
cheese's Avatar
GA
05-23-08, 09:38 PM   #6
2 strokes rev high. If you have it running too lean, it will rev extremely high and score the cylinder very quickly, ruining the engine. Get it to the highest rpm, and open the H screw a bit until the high speed comes down and the engine gets a bit of a flutter sound to it.
God bless!
minibiker's Avatar
OR
05-25-08, 09:56 AM   #7
Ok thanks. I also put a lil bit of extra oil in my gas just incase.
