oil light on
Old 05-24-08, 11:00 AM
oil light on
my oil light comes on only when i engage blades. How do i check oil pressure? I had valve cover off and ran engine a few minutes oil apprently getting up there as oil was running out.
Old 05-24-08, 05:56 PM
hopkinsr2's Avatar
What are you working on,, Techumseh, Briggs, kubota, tractor, zero turn, the options are endless. Give the pros engine numbers & unit make & model & they can help you out<<<< Roger
Old 05-25-08, 01:03 PM
briggs /stratton 14 hp ohv 28p777
Old 05-26-08, 12:00 AM
cheese's Avatar
Use an oil pressure guage and check the pressure. Screw it into the port where the oil pressure switch is.
Old 05-26-08, 07:23 AM
I have a briggs 28p777-q644a1-970404zd.Oil light only comes on when i engage blades. Thanks
