power washer problems
Old 05-26-08, 12:07 PM
I have BE-Power Washer with a :
Honda 5hp motor (GC160)
Comet Pump ART# AXD-6501001400
MATR# 29290966
The power washer does not have any pressure. I power washed my fence and then went down to my brothers to do his house and I couldn't get no pressure from it.
It was working before I brought it down there, so I thought not enough water pressure. So I brought it back down to my house and it still won't work.
The pump does not seem to kick in at all. I've read on here that it might be the unloader, so I took it apart and it the little piston seems a little sticky, o-rings seemed okay.
How do you change the unloader? Is the unloader all one piece because it sure looks like it is?
Any ideas what to look for?
Old 05-26-08, 07:54 PM
cheese's Avatar
Received 17 Votes on 15 Posts
Usually you can clean the unloader and lube it to get it functioning properly again. Also clean the bore where the unloader fits.
Old 05-27-08, 04:32 AM
What & how would you use to clean & lube it. I have never done this before, its all virgin territory.
I was thinking of using sandpaper and regular engine oil 30w, would that be okay?
I have looked at the expanded view of the Comet Pump and 18-28 is what your referring to, right? I have attached a copy below.
http://www.bepressure.com/pumps/axd-brkdwn.pdf
By what I've described does it sound like the unloader to you?
Old 05-28-08, 12:30 AM
cheese's Avatar
It sounds like the unloader could be to blame. The parts you listed are regulator parts. By looking at the diagram, I think the unloader parts are shown in the group identified by #60?
I use a brush for gun barrels or bottle brush. I have several sizes, from shotgun barrel brushes down. This will clean the bore area well. Then clean the piston and o-ring, or replace the o-ring, and I have good results with petroleum jelly for lubricating parts in a water pump.
Old 06-09-08, 08:30 AM
Well I have it fixed. I brought it in to shop and he said it didn't need any parts.
He said he disassembled the pump and cleaned up the valves and its working like new.
Thanks again Cheese for your help, I appreciate it
ps: Cheese, for future reference, the parts I listed was the unloader valve. Thats what the mechanic said.
Old 06-09-08, 09:41 PM
cheese's Avatar
GLad you got it! Thanks for the update.
