20 HP Intek surging
SteveH_1919's Avatar
VA
05-30-08, 06:26 PM   #1
20 HP Intek surging
Hi all,
I have a JD L118 with a B&S 20HP Intek (MN 406777 Code 0139)
that is surging during usage. When the surging occurs, the mower will maybe run with the Choke full on. I let the mower sit for an hr or so and it starts to surge after 10-15 min.
I have replaced the fuel filter, fuel pump, and the air cleaners. None of this has helped. The problem has gotten progressively worse over the course of a month.
I cleaned the carb and the jets. I freed up the fuel shut off valve. The problem persists.
Any ideas?
Thanks
Steve
cheese's Avatar
GA
05-30-08, 09:36 PM   #2
Hi Steve,
Does the engine run fine to begin with, and then begin to surge after a period of time? If so, loosen the gas cap and see if it corrects itself.
If it surges from the beginning, I'd suspect a carb problem. Surging is caused by not enough fuel.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
VA
05-31-08, 03:55 AM   #3
surging 20Hp intek
Thanks for the reply.
I'll give that a try.
Thanks,
Steve
