Gas Lawnmower help - Smoke coming out!!! PLEASE HELP!!!
Old 05-31-08, 09:09 AM
Unhappy Gas Lawnmower help - Smoke coming out!!! PLEASE HELP!!!
The smoke is coming from my carburetor I don't know what the problem is just that too much smokes comes from the carburetor, but otherwise eveything else works fine. I just added new oil and gas.
also the lawnmower acts like it is choking and then sipts out a lot of smoke. Goes ok for a few seconds and then chokes again and spits out some more smoke. Then I turn it off thinking it might be serious.
brand is Yardworks from Canadian Tire
6.5 HP (model # unknown)
please help... thanks
Old 05-31-08, 05:34 PM
Received 3 Votes on 3 Posts
Sounds like it has to much oil in it , check the oil level and post back. Have a good one. Geo
Old 06-02-08, 02:52 PM
thanks for responding. Actually it had too little oil so i added it and it worked. After I was finished cutting my grass I checked the oil again and it was almost empty, however it did not seem to have been leaking. So why does the oil now go down so rappidly?
PS. Actually the thing that was smoking is called a muffler.
Old 06-02-08, 10:46 PM
cheese's Avatar
Received 22 Votes on 19 Posts
Ahhh...from the carb could indicate too much oil. From the muffler would indicate that it's using oil...probably because of worn rings and/or damaged cylinder.
Old 06-03-08, 03:06 PM
How do I fix the worn rings on the piston? I mean I only had the lawmower for 3-4 years. So why should it give me problems already? Should I take it somewhere to get fixed?
Old 06-04-08, 01:20 AM
cheese's Avatar
It might not be rings...could be a blown head gasket if it's an OHV engine, or a breather problem. If it's rings and cylinder, it's not worth fixing.
Check to see if oil is blowing into the air filter housing. If not, the head gasket is probably not the problem, and the piston rings and cylinder probably are. The best way to tell for sure is to pull the head off and have a look..
Old 06-04-08, 02:39 PM
it's not worth fixing? I had the lawnmower for only 3-4 years. Or are you saying I should get it to a repair shop and they will fix it? But why did it break after only 3-4 years? It's pratically new machine.
Old 06-05-08, 12:31 AM
cheese's Avatar
I said if it's the rings it's not worth fixing. If it's the head gasket, it probably is worth fixing. If it's the rings and cylinder, it will cost more then a new engine to repair it. I don't know why it broke....things just break. 3-4 years isn't new for a low-end push mower. Many of them have met their demise by then, depending on how they're used and cared for. Some last for 10-15 years.
Did you remove the air filter and look at it's condition?
You said it had too little oil, so you added oil and it worked. So it quit working before you found out that it was out of oil? If so, that is why it broke.
