High RPM cut out
Old 05-31-08, 11:06 PM
High RPM cut out
I have a Honda 4 stroke gx25 on my weed whacker. It idles and starts great but when running at high RPMs it will die. It does it cold or hot, and will restart immediately. Sometimes cold it will run for a few minutes. I took off the carb and cleaned it out, it looked great and I could see no visible problems. I also put in a new spark plug and fresh gas. What am I missing? I appreciate any suggestions.
Steve.
Old 06-01-08, 08:27 PM
Come on guys, I need your help here.
Old 06-01-08, 08:53 PM
cheese's Avatar
Received 17 Votes on 15 Posts
When you re-start it, how long does it run before dying again? Does it shut off dead cold like it was switched off, or does it wind down like it is running out of gas?
Old 06-06-08, 10:00 PM
It will restart immediately with 1 pull but cut off within a few seconds when under full RPM. It cuts out fast and cold unless I let off on the throttle then it will idle forever. Like its either starving for gas or flooding. There are no adjustment screws to play with.
Old 06-07-08, 07:14 AM
bontai Joe's Avatar
What does the air filter look like? Need replacing? I'm thinking that it may not be getting enough air at high rpms.
Old 06-07-08, 07:38 AM
Gunguy45's Avatar
Super Moderator
Not sure, but is there a fuel filter? Pro's?
Old 06-08-08, 12:10 AM
Air and fuel filters are OK. I even tried running without them and no change. NEXT?
Old 06-08-08, 08:35 PM
cheese's Avatar
Sounds to me like there may be a piece of trash pulling up into an orfice at full rpm, or a partially restricted strainer in the carb if the carb has a strainer screen.
