Pressure Washer not running
af66's Avatar
NY
06-01-08, 07:50 AM   #1
Hopefully someone was some guidance on this...I'm pretty much out of options here...I have a NorthStar 2100GPM Pressure washer with Comet pump and Honda 5.5HP engine...when taking it out from storage this winter (I had drained the tank) and trying to start it...I had no luck...wouldn't even turn over. So, here's a list of things I've tried:
1: Drained tank again
2: New spark plug
3: disconnected "low-oil" shutoff
4: cleaned out carb (Gumout small engine carb cleaner)
5: cleaned air filter (it was pretty clean to begin with, but just to be sure)
6: adjusted choke and throttle
7: took off fuel line and blew air through it to clear any restrictions
8: checked valves (thought one compression spring might have been stuck, so I worked it free)
9: checked gas cap to make sure it wasn't defective
with all of that done, the symptoms are now that the washer will start only if I spray starting fluid in the air filter, but then after one second it will shut off....then it won't start again unless I spray more starting fluid and the process gets repeated.
If anybody else has some insight or help, I'd appreciate it. Thanks in advance.
cheese's Avatar
GA
06-01-08, 09:43 PM   #2
You'll need to clean the carburetor. It's gummed/varnished up inside. Drop the bowl and have a look.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
