MTD tranny question
Old 06-01-08, 03:13 PM
MTD tranny question
Greetings everyone,
I have a Cub Cadet 1170 with a MTD 618-0307B tranny on it. Anyone know how or if I should re-grease this thing?
I am replacing all the belt and have a Brand New 21hp Briggs on it so I figured I should do a little maintenance on the tranny to. Problem is I can't find any type of drain plug or grease fittings on this thing.
Anyone have any ideas?
Old 06-01-08, 04:13 PM
oldchevy4x4's Avatar
More than likely you'll have to pull the transaxle out and split the case to clear out the the old grease or add new stuff.
Just be sure to use bentonite grease when you re-lube it...
This is especially important if you're just adding to the existing grease: thumbup:
Old 06-03-08, 05:22 PM
Anyone know where I can get bentonite grease? Not Autozone, Advance Auto or the 2 local Cub Cadet dealers.
Any ideas?
Old 06-05-08, 07:32 AM
It is filled with grease at the factory, and should not
need any added. If moisture has gotten into it, then disassembly and thorough cleaning is needed to remove the rust, but if it is working well, I would suggest that you
leave it alone. Just ny opinion.
Fish
Old 06-05-08, 09:19 AM
CAMINO KID's Avatar
Any ideas?
Your best bet is a Tecumshe dealer. It comes in a tube and is semi fluid. I do not have the tecumshe or peerless part number handy at home.
